Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
D2 Coilovers
Old 08-06-2012, 09:15 AM
  #41
Skidmarcx's Avatar
I hope they do as well... give us some reviews after you drive it a bit
Old 08-06-2012, 02:48 PM
  #42
lollygagger8's Avatar
So do you need to go with Z06 endlinks? Or have your factory links not broken yet?
Is the ride any stiffer? Like, jarring?
Old 08-06-2012, 03:11 PM
  #43
whazard's Avatar
My factory endlinks are still going strong but I was actually just looking at others to change them out.
The ride is a little stiffer but I wouldn't say jarring. I was actually expecting it to be a lot stiffer than it was.
Old 08-06-2012, 07:10 PM
  #44
54inches's Avatar
What I wonder about, is why people feel necessary to quote the pictures.
It appears you are setup just a tad lower than stock; how does it ride as is?
Cheers,
Old 08-06-2012, 07:23 PM
  #45
whazard's Avatar
Originally Posted by 54inches
What I wonder about, is why people feel necessary to quote the ******* pictures; what are we 12?
Cheers,
The ride feels about the same really. Everything just feels more planted. Going through a curve at the speeds i usually do feels like I am going slow now. I am planning to lower the back a little more but the front is as low as I can take it without scrubbing when I hit a big dip or bump in the road.
Old 08-06-2012, 07:34 PM
  #46
etcts-v's Avatar
Great pics, thanks for the share! Def gonna pickup a set of these for myself.
I'm confused why people are confused, the way the car is setup they have to be separate coils from dampners in the back do they not? There is no alternative way, or maybe I'm crazy.
Old 08-06-2012, 07:45 PM
  #47
whazard's Avatar
Thanks. Wish I would have remembered to take more.
These are the only ones I have seen that are a one piece design for the rear.
https://ls1tech.com/forums/cadillac-...torsports.html
Old 08-06-2012, 11:04 PM
  #48
Onefast V's Avatar
These are the one's i wanted to get but they were just too much unfortunately
Old 08-07-2012, 06:41 AM
  #49
furbe's Avatar
Some more D2 smack for ya, I did some espairmentin with these awhile back and as you can see it is possible to convert these to true coilover rear with the parts they come with. Since the rear shock body is threaded you can use the rear spring adjuster, thread it onto shock and I had to use the front 8 inch coil spring. The rears are 10 inch and will work on the front. Not ideal as I had run front adjuster all the way down to get a 10 inch spring to work on the front.
Second picture shows a 10 inch 625# hyperco 2.5 front spring. Should have used an 8 or 9 inch. I felt that I needed a bump stop in the front so I cut down the stock ont from my FE4s. Thats what you see in the pics.
Hope this aint too many pictures to post here. I just had them so wth. More on my photobucket if you wana see more on this ****.
Here is the D2 front spring and the 10 inch hyperco
More of the rear converted
This last one is the front shocks with the D2 rear springs installed. (i painted them yellow but they are the rear springs that come with the kit.
Old 08-07-2012, 07:31 AM
  #50
whazard's Avatar
Thanks for the pics. How is the ride with them setup like that?
Old 08-07-2012, 07:57 AM
  #51
furbe's Avatar
Never drove it that way. I just put them together real quick when I first got them to see if it was possible.
As far as changing the front spring to a stiffer hyperco, I had to do that for track duty. Rear also. Springs that come with are too wimpy for track use.
10 inch rear and I would go with a 9 inch front 2.5 I.D
Old 08-07-2012, 08:28 AM
  #52
Onefast V's Avatar
This is the stuff i like to see here. So it is definitely possible.
Old 08-07-2012, 09:23 AM
  #53
Skidmarcx's Avatar
I'm interested to know how it affects handling
Old 08-07-2012, 10:20 AM
  #54
etcts-v's Avatar
I love the creativity, I would be curious to see how it rides as well. What is the benefit of going this route?
Old 08-07-2012, 02:54 PM
  #55
Onefast V's Avatar
FYI if you move the rear spring outboard, you need to compensate by lowering the spring rate significantly. LG coilovers are 700F/400R.
Old 08-07-2012, 04:59 PM
  #56
Onefast V's Avatar
Ordered a set on ebay. Seems 910 is the lowest they will go.
Old 08-12-2012, 01:52 PM
  #57
liqidvenom's Avatar
im curious to see if someone will run the rears with that combined setup.
Old 08-12-2012, 04:24 PM
  #58
Onefast V's Avatar
I fully intend to run the rear as a coilover setup.
Old 08-12-2012, 04:57 PM
  #59
NeverSatisfied02's Avatar
Nice! I'd like to know how it changes the ride as well but im pretty sure my current ground control setup will be good enough for me.
Old 08-12-2012, 05:53 PM
  #60
Onefast V's Avatar
It will be a while as I have many things to get done first. car is always up on jacks for a new clutch. then the truck needs attention.... god cars are just bottomless money pits
Quick Reply: D2 Coilovers
