CS MotorMounts installed today
Just finished the install a few minutes ago. HOLY HELL what a pain in the *** that was!!... How much $$$ in labor would a dealer have charged me?? I'm trying to make myself feel better lol
Here is the only picture I took. Had to trim the heat shields a little b/c they were a little long.
Haven't started it up yet, but my old driver's side one was spewing out so I'm sure it'll be an improvement.
Judging by the picture, they were trimmed because the shield was installed on the top of the mount, not the bottom. That's how the stock heat shielding is installed.
When I had done mine, I put the CS heat shielding on the bottom of the mount and that required no cutting.
The shield is supposed to go on the top of the mount. Not only to protect it from heat from the headers/exhaust manifolds, but the heat from the engine block itself. If you did install it on the bottom you mounts will be in direct contact with the heat from the engine block. This is what caused my previous CS mounts to fail. Yes the heat shields are longer but don't need cutting. You must have installed them incorrectly.
