5 lug cts wheel hub direct swap with ctsv 6 lug?
Alrite guys, I've got an 03 cts 5 lug and 06 cts v 6 lug. My cts v is sitting whilst rotors gather rust and it bothers me. So I was wondering if i can swap them and even the calipers if possible. How long will it take? Any modifications? Pros? Cons?
The base CTS and the V share the same brake lines, however, there is a recall on the CTS lines and you my want to see if you are covered before the swap. Or you can inspect them yourself as well. There is a foam peice that covers the joint where the hose is crimped into the metal fitting that bolts to the caliper. This foam holds water and dirt and causes corrosion of the fitting and eventually the line will fail. This is a good idea on the V as well because for some reason the V was not included in the CTS brake line recall.
Doing a 5 lug swap can't be this easy or everyone would be doing it.
Just to clarify....you guys are saying you can bolt the CTS 5 lug hubs on the V1 then re-drill the V1 rotors, bolt the V1 caliper on and plug the abs connector in and everything works???
Then why is everyone using the corvette hubs??
Why is it so hard? Yes, the CTS 5 lug hubs are different than Corvette/Camaro hubs so that combo wouldn't work. This guy is trying to swap out the entire set up so he won't have an issue. If you want 5 lug and want to keep your big brakes I would imagine you could switch to a Corvette hub/rotor, or to a new V setup. But I don't think the new V has the same pattern as the Vette/Camaro.
No need - the spindles are the same.
