Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Rear swaybar bushings
Old 05-15-2014, 07:59 PM
isis's Avatar
Default Rear swaybar bushings
I know creative steel makes urethane fronts because they are weird sizes but are the rears something that can be picked up just by dimensions? I don't feel that I'll ever change the swaybars so I just want to get better bushings and install Zerk fittings.
Old 05-16-2014, 07:06 AM
ls1247's Avatar
From what I remember CS is working on a solution for the rears...I think it would sell well
Old 06-16-2014, 12:14 PM
isis's Avatar
I got under there to do some other work the other day and found that the universal ones will work fine. The bar measures 20.7mm and the bolt centers on the brackets measure 3.5" so any 13/16" bushings with a bracket that works for those bolt dimensions should be fine. I'll post the energy suspension and prothane part numbers I found a little later. I ordered the energy set for just a little under $20 shipped. Red to match my front ones from CS..
Old 06-16-2014, 12:47 PM
isis's Avatar
Prothane 19-1131
Energy Suspension 9.5107
Quick Reply: Rear swaybar bushings
