Service airbag codes B0066 B0092 U1016
06 V 85k never in an accident to my knowledge.
The service airbag like is pretty much constantly on. Clear it from the NAV, hit a bump and it's back on. Scanned it today and got the 3 codes:
B0066 LF Pretensioner deploy loop volt range
B0092 passanger presence system 1 circuit fault
U1016 lost comm with ecm/pcm/vcm
Cleared all the codes and the only one that came back immediately was B0066. Took apart as much as we could of the driver seat, checked all connections and everything looked good. Searching I didn't find anyone with similar issues or any fixes. Any feedback on how to go about fixing this/checking connections?
Wiggle the sensor under the seat. The front passenger seat. see if that helps. Mine gives me the warning if i have someone move the seat all the way back. I move it forward an inch then check that connection. Bam goes away.
I'll try moving the seat up a little. I already wiggled/disconnected and connected everything. I planned on removing the seat once it warms up and cleaning everything up/making sure all connectors are making a good connection. I notice it happens less when I am buckled up. Yet it always comes on. If it's off and I hit a bump it comes on.
For the PPS there was a recall at one point. When I enter the vin on GMs website the key rotator and fuel pump jumper harness are the only open recalls. No remedy for the jumper harness so they won't fix that. Not sure if the repair was ever made to the PPS from previous owners. The seat cushion looks like it was messed with so I wouldn't be surprised if someone tried messing with it.
