Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Stiff clutch pedal
Old 05-29-2015, 07:16 PM
bmylez's Avatar
Originally Posted by heavymetals
Could be the pressure plate is binding as there are a lot of moving parts there.
One of the "fingers" could be bent.
But then how was it soft for a week? Put in new OEM master, pedal was ******* *awesome*, bled it the next weekend, back to stiff...
I inspected the pressure plate fingers today. They look perfectly normal. Last thing I'm trying is taking off the Tick slave line and using the C6 line. Technically shouldn't make a difference since I verified no blockage, but it's the only thing I haven't replaced.
Old 05-29-2015, 07:20 PM
heavymetals's Avatar
All the resistance in the pedal should be due to the pressure plate spring action.
The hydraulics should be a very small contributing factor.
Old 05-29-2015, 07:25 PM
bmylez's Avatar
But no thoughts on the 1 week of blissful pedal pressure.
Old 05-29-2015, 07:30 PM
My thoughts are that somehow the pressure plate changed.
The fingers may look fine and it may look ok, but that doesn't tell you if anything is binding.
The crappy thing is that it is hard to tell.
I assume you didn't reuse any of the old fluid, so system contamination is probably not suspect.
Old 05-29-2015, 07:33 PM
bmylez's Avatar
So you're saying the pressure plate was one way from December until early May, then it changed for a week, then it changed back...?
Old 05-29-2015, 07:42 PM
I am not saying what it is, just what it could be, since you have ruled everything else out.
It is not unheard of.
Usually, master/slave binding is from contamination or rust.
The clutch disc could be hanging up on the splines although that should effect engagement.
One thing that might also be the culprit is that the flywheel is warped and the clutch assay is not sitting flat.
Here is a link to a good read:
http://www.g-w.com/pdf/sampchap/9781605252131_ch07.pdf
JUST A THOUGHT:
I seem to recall someone had a very similar problem and he fussed over that thing for days.
Turned out he had bungled connecting the slave to the master somehow where it was working like yours is, if I recall correctly.
Old 05-29-2015, 08:27 PM
bmylez's Avatar
Alright, instead of swapping in the C6 slave line for the Tick line, should I just bite the bullet and pull the clutch and test my stocker? I suppose if I have everything basically apart I might as well. Just doesn't seem like it's the culprit, but there's nothing left to replace! Wish me luck...
Old 05-29-2015, 09:13 PM
I don't understand why you are swapping slave lines, unless the slaves don't come with them.
The ID's aren't that much different are they?
Old 05-29-2015, 09:29 PM
bmylez's Avatar
The line that comes with the C6 slave is longer than factory and you have to bend it. Tick makes a nice steel braided line that is shorter and cleaner. Yes, they have the same ID, but I'm just thinking of anything and everything I haven't tested against. I have the bellhousing off now, will swap clutch in the morning. Time for a motherfuckin drink.
Old 05-29-2015, 10:49 PM
Welcome to mod hell.
Old 05-30-2015, 12:49 AM
Grenade19's Avatar
Is there any chance your clutch pedal is bent in any way ? You've changed 1 of the 3 systems in the clutch circuit but have not found it to fix anything. Maybe disconnect the clutch rod and start looking around for any interference.
Hope you find it.
Old 05-30-2015, 06:41 AM
  #32
bmylez's Avatar
Hope you find it.
I've changed more than 1 thing, but as far as the pedal being bent, not sure how that would happen. The clutch pedal spring broke at some point between my 2nd and 3rd master cylinder, and I didn't notice it at all. I checked to see if the broken spring binds up on anything while depressing the pedal and it doesn't. With the master cyl rod disconnected, the pedal pops right to the floor.
Additionally, if the pedal were bent, then I wouldn't have had that week of easy pedal pressure. It would be easier for me to believe there was a fluke in the pressure plate than for the pedal to unbend itself, then bend back.
Old 05-30-2015, 08:39 AM
  #33
gtistile's Avatar
I noticed you mentioning bending the slave line... Is it possible you've crimped it somehow? Any time I do something out of the box, I end up notching the bell housing to accomodate where the slave line comes out instead of trying to bend the slave line... I tweaked my bleeder line a too hard of any angle once on an LS9 slave and it caused it to allow air in to the system. Try to keep everything as strait as possible as intended. Just a thought...honestly can't believe this is still happening
Edit just re-read your post about the bend... I know what you're talking about though I've never used any of the slave lines that come with the actual slaves. I've always used a long stainless braided line that is connected directly from the tilton master to the slave, no disconnect point
Old 05-30-2015, 09:27 AM
  #34
bmylez's Avatar
I'm running a used flywheel that I bought from someone on here but I had it resurfaced before install...still a possible culprit?
Old 05-30-2015, 11:48 AM
  #35
Used anything is suspect, but the flywheel should have been flagged by the surfacer if warped.
You have it apart, start with the hydraulics.
I don't know what bleeder you have, but I would clamp the slave from moving and open the bleeder and pump fluid.
If it pumps easily with little effort, I would say go to step two.
That is the pressure plate, which could be binding.
I will skip the slave as you say it is new although that is not a guarantee that it is not the culprit.
TRUST NOTHING.
If the flywheel is warped, the clutch assay will not be "true" and the slave will be trying to push on a pressure plate that is at an angle which may bind with the springs and guides.
Did you install the flywheel the proper way?
Fidanza(?) requires an oven preheat before you mount it.
Old 05-30-2015, 12:59 PM
  #36
bmylez's Avatar
I have very promising news. I put the stock clutch on just now, mounted up the trans, bled it (with a Motive bleeder; plenty of fluid went through it), and the pedal feels exactly as it should. So as of now, it LOOKS like it might have been the pressure plate.
As for the flywheel, it was off of someone's LS2, so it's just a stocker. I tightened it in the proper sequence up to 73 ft-lbs. If the pedal remains stock stiffness for the rest of the week, it won't matter because I'm going to order a new flywheel and a new OEM clutch since I shouldn't be running a mismatched flywheel and disc, unless you disagree. Only 3k miles on the resurfaced flywheel, but I don't know the abuse or mileage before that.
My plan right now is to attach the driveshaft and test for proper engagement while it's in the air. A soft pedal isn't worth anything if the car doesn't move at all/move correctly.
Old 05-30-2015, 01:57 PM
  #37
Don't go with an OEM clutch (IMO).
I would go with an LS7 package and get it balanced before you install it.
I use an LS9 twin disc and it is as smooth as the OEM was.
Old 05-30-2015, 02:54 PM
  #38
ls1247's Avatar
Even though you're problem doesn't appear to be related to this, the shimming issues we've seen with the various flywheel/clutch combos that can go in this car would make me think twice about taking very much at all off the flywheel.
Old 05-30-2015, 03:47 PM
  #39
bmylez's Avatar
So you're saying put the same thing back in that I just got done running around in circles trying to figure out? I'm sure you can appreciate the irony. It sounds like I just got a bad pressure plate, but now I'm very skittish. The 4th time I have to drop the trans, I'd like it to be something that has a higher chance of having a soft pedal, so that leaves OEM or LS9. One reason I don't want to get the LS9 is I will never, ever, use it to its full potential and it's also difficult to justify the cost when I want to do 5-lug wheel conversion and freshen up the motor.
Old 05-30-2015, 04:37 PM
  #40
I thought you were going to buy a new clutch package, not a used one or try to cobble one together.
Whatever you do, this time get it balanced and make sure it is flat.
Quick Reply: Stiff clutch pedal
