Intermittent Service Stability system
Occasionally on start up my car will flash "Service Stability System" on start-up. It will not happen again if I restart the car. I do also seem to be having issues with the right front TPMS sensor. Occasionally it will jump to high 40's in psi, then it will either go blank or go back to the proper low 30's psi. Though these issues don't seem to be related, are they? Is it just a goofy TPMS sensor causing the Service SS? I've only changed one sensor and the car is an '05.
