Hood vibration at highway speeds
The two hing bolts just come out, they have a large shoulder on them. No pics but if you search around for the hood rattle you will find others that have made nylon washer from Home Depot work but they stopped carrying them
Raven he is still missing the air dam and that's the biggest issues he has, im guessing he is not wanting to pony up for it. Nothing will be fixed with out it. The hinge rattle is just another notorious thing to look at but will not cause his issue
So after a balance and moving the best rollers to the front almost all of the vibration was gone. Turns out the hood was vibrating because of the wheels.
I do still have one issue which persists. I get some vibration through the steering wheel from 55-65 MPH but not outside of those speeds. Any ideas on that one?
How slight of a vibration is it? What motor mounts do you have? Dunno if that's the source or coincidence but I have had a very slight vibration in my wheel only after I went aftermarket mounts. I will live with it as is but I had them balanced 3 times before I was able to get an acceptable balance from them. The rest I attribute to all my driveline being poly mounts
i have this too. I'm nearly certain it's just the tire tread and compound causing resonance vibrations. Or such a slight imbalance the shops can't get it 100%. I have Goodyear eagle RSAs on the front. It was worse when I had 4 of them. And the first set got replaced within days b/c of broken belts. Also the problem got worse when I had one replaced after an accident. I already didn't like them so I was miffed that I had 3 nearly new ones instead of the two half worn that were on the back. I had a bit of a fit when they asked me to pay the prorated difference since the damaged tire wasn't new. I told them to find me a used tire or eat it. Pretty absurd.
Radial Tire Vibrations
Going back to the 1970's, there has been a tire engineering phenomena of radial tire vibrations in the 50-53 mph range with some brands on some cars that sometimes just can't be balanced out. Most people just don't notice it since they drive through the range on their way to 55+ mph. I've noticed it with Goodyear, Goodrich, and Michelin. I've spent hours on some of my cars using both static and dynamic balancing machines and sometimes just can't seem to get it all out.
