Crank Relearn not possible
I used EFILIVE,
Parking brake applied,
car started and idling
ECT 85-95c
Brake pressure applied
connected to ecu
clicked on crank relearn
DVT FAULT
HP TUNER
same as above, but no action
Tech 2
Start engine and idle flashes all the time, and am unable to proceed
Does anyone have any thoughts?
ECT 85-95c
connected to ecu
DVT FAULT
HP TUNER
Tech 2
Originally Posted by jmilz28
My only suggestions - check with a known good crank sensor and double check the connections - you probably already did, right? Didn't you put a whole new harness in this car, am I thinking right?
