UUC Rear Diff Bushing
I just order a set of the UUC Shifter Bushing for Lindsay, and I got to thinking. I am going to be ordering a set of Kooks from them here in the near future. And when I do that, I was thinking about getting the Poly Rear Diff bushing as well.
The questions are:
Is it worth it to order for the 07 Rear?
Its only 90 bucks, but how much would it cost for and install?
Also, this may be retarded, but when I it most of what comes up is the Cradle Bushings...is this the same set of 4 as what I would get from Luke?
The questions are:
If you have a clunk, then it's worth it as it reduces it a decent amount. Install is probably a pain unless you have a diff tool to use or some other sort of press. I did it myself with one of the diff bushing tools and it was pretty simple. No tool and I'd have been hurting...
The cradle bushings are different than the diff bushing...here's a link to some pictures of my install:
http://www.ridgidconnect.com/Home.as...m3knFd36Wlk%3d
Hope this helps,
Brad
Hope this helps,
Brad
