Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Tire pressure sensor not working
Old 07-04-2011, 01:48 PM
Rick_815's Avatar
Default Tire pressure sensor not working
I took off the wheels to get new tires and for some reason the rear driver side tire dosnt even show a 0 reading. All it shows it the 3 lines going across. Can somebody help?? Thanks
Old 07-04-2011, 02:04 PM
swiss's Avatar
Try resetting them:
http://www.cadillacfaq.com/faq/answers/tprepro.html
Old 07-04-2011, 02:12 PM
Rick_815's Avatar
I tried that when I had the wheels on. And it just got stuck for like 30 min on that same one that's not working. Thanks for the fast reply.
Old 07-04-2011, 02:18 PM
vmapper's Avatar
perhaps create a larger PSI change just to ensure it sends the RF signal... only other thing really is the battery is dead..
Old 07-04-2011, 02:20 PM
Rick_815's Avatar
What battery??
swiss's Avatar
Ah, I see.
Old 07-04-2011, 02:25 PM
Rick_815's Avatar
Is there any way to just check the sensor itself?
Old 07-04-2011, 03:09 PM
NeverSatisfied02's Avatar
Discount tire has a tool that resets them. If that doesnt work, i have like 3 extra sensors in my garage. If yours is bad, ill sell you one for cheap.
Old 07-04-2011, 04:24 PM
vmapper's Avatar
What battery??
How do you think the RF signal is sent by the sensor inside your wheel? They need power to send the value to the car to put that number on your dash...
they are activated by pressure CHANGE, hence the calibration procedure for your car to pick up the RF signal...
(same as your key fob... which also has a battery )
Typical TPMS sensor battery lasts 7 or so years.
Old 07-04-2011, 05:07 PM
Rick_815's Avatar
Oh ok. Thanks guys!! I'm taking them to a friend that works at a gm dealership to check them!!
Old 07-08-2011, 02:14 PM
Rick_815's Avatar
There was one bad sensor. Thanks for the help guys.
Old 07-08-2011, 11:20 PM
jenks40's Avatar
your tire guy broke the sensor. they should pay for it...
Old 07-09-2011, 08:31 PM
Rick_815's Avatar
No it had been going on and off and finally stayed off, so that's y I took off my wheels.
Quick Reply: Tire pressure sensor not working
