NO BRAKE LIGHTS....Help a brother out!
Check the brake switch.
Check out the link below. Anti-Lock Brake PDF for the CTS.
https://docs.google.com/file/d/0B_xx...it?usp=sharing
Right, Brake Pedal Position Sensor (BPP Sensor).
If it's responsible for killing the cruise, that worked. Now, it might not be working entirely correctly, just enough to kill cruise, but it at least did that.
I will see if there's some diagnostic in the pdf about the BPPS.
I went through this problem a little while ago.
My switch ended up being fine, it was the Neon light bars and specifically the BALLAST for them that ended up shorting out.
Problem: No brake lights, running lights worked fine.
Solution: Replaced corresponding fuse (BAS fuse in box behind drivers seat).
I unplugged the 3rd brake light from the harness to make sure that really was the problem. Fuse didn't blow anymore.
I replaced the neon tubes/ballast with a $25 autozone ricer LED kit after taking apart the whole third brake light.
Good times.
-meaty
Good times.
-meaty
