Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
FG2 install rattle
Old 12-31-2012, 12:32 PM
chitown21y's Avatar
Default FG2 install rattle
I installed a slightly used pair of FG2's to replace my old fe4's and when I hit the test drive the LF FG2 rattles when hitting quick bumps like entrances to parking lots and manhole covers? I have triple checked all the bolts have new sway bar end links and torqued to spec so my question is can the fg2 be bad?
It didn't do this with the fe4's and I have now taken it apart 3x.
Its not leaking but wondering if it can fail internally?
Thanks,
Dave
Old 01-07-2013, 01:26 PM
CTS-V Shifter Sales
07CTS-V's Avatar
Swap it out with the RF one. See if the noise follows.
Old 01-08-2013, 12:16 AM
chitown21y's Avatar
Yeah I swapped the old one back in a the noise is gone so bought a bad fg2 I guess. Thanks
Old 01-08-2013, 12:38 PM
Fuzzy_Wuzzy's Avatar
could the spring have not been fully seated?
Old 01-08-2013, 12:47 PM
chitown21y's Avatar
I made sure it was seated. The shock will not rebound after I push it in like the fe4 or other fg2 I have so I am assuming its a goner. I also tested on the freeway and could feel it bouncing around like a rubber band.
Quick Reply: FG2 install rattle
