Strut brace question
Bought a BMR strut brace, nice piece. Torqued strut bolts back down to 82 but no instructions for the horizontal bolts that thread through the mounts and the bar. My initial thought was these should be tight so the bar doesnt have play in it so I torqued the **** out of them, then I realized it may need some play in between and is more to tie the left and right struts on the horizontal plane than to make everything completely rigid. Anyone know how tight to make these?
What ls1247 said. There's a bolt size/hardness/material torque chart that usually works when the manufacturer fails to provide specs. In this case I'm thinking you do not want ANY play in the bolts since rigidity is the goal here.
Assuming 10.9 metric bolts?
