brake issues
brake issues
Have an 05. All of a sudden the brake pedal goes to the floor when depressed. It still stops but is worrying me. Displaying "service stability" message and check brake fluid. Just topped off brake fluid recently. No leaks in driveway. Anyone have any ideas. I dont want to take it to the stealership
Sounds like fun... Its a game really... When will I run out of DOT3... If you lose... You die. Haha. I remember this game in my 1955 Apache 3100 4x4.
Brake lines should be 100% sealed and shouldn't require any filling. When you replace pads and you push in the caliper's pistons, fluid should go back into the master cylinder reservoir. As you use up break pad, fluid goes into the lines and out of the reservoir. So either... Your pads are beyond worn, or you have a leak somewhere. The whole system should be inspected for leaks.
1 Post
Probably blew the line off. Check the inside of your wheels and see if you see brake fluid there. May not be showing up on the driveway, because its landing inside of rim.
I would put my money on a failed line. I've had BOTH my front brake lines fail, causing it to only grip when its at the floor, and under harder braking, it feels like the rear locks up like that.
