This Damn E67 ECU; alternatives, more tuning options etc...
So, bringing back the topic of getting this damn E67 ECU and some real tuning parameters for higher boost levels... Bill at HPtuners has all but refused to do anything for a OS upgrade for us V owners. I urge everyone on here to write him (bill@hptuners.com) and ask for a E67 3bar OS upgrade. Sooner or later this may effect you as it is severely hurting me right now. My tuner is not comfortable tuning mine with the power levels its capable of with out the parameters this offers and no RTT either.
I am looking into a rumor that some TBSS e67's have 3bar os' and if they can be swapped to the V, anyone know?
Also rumor that EFI Live may have an Ethanol specific setup for E67's again, anyone know?
And lastly, what about swapping the e59 from the 04-05's, and do these have any os upgrades?
Does EFI Live offer anything? I know they actually have better custom OS' than HPT does. I'm pretty sure writing Bill will have no effect for a PCM that is almos a decade old, the HPT guys in general are pretty arrogant and/or obtuse so if thy said nothing is coming they would likely hold to that on principle alone.
Sorry man, sometimes it's just easier to find a way around City Hall than going through it.
But yeah i think a standalone isnt far off....
Are you just wanting a 3 BAR OS? Doesn't the E67 natively support 2.5 BAR anyhow? You shouldn't need the TBSS PCM, you should be able to load the TBSS OS in your E67 if the cal's are similar. I though the major shortfalls of the E67 was the MAF and injector hard codes in the software. You'll have to scale the injectors for sure, but your current E67 should be good for 21 PSI from what I remember.
Although, at your level I agree it may be time to step up to an aftermarket system. While the high $$ **** isn't bad at all, I would not discount Micro Squirt. You can build it yourself and MS3 had everything including variable (PWM) meth and nitrous control by both RPM and vehicle speed. It's pretty cool. The Buick guys are having a blast with it.
You might also get better responses posting over in the PCM/Tuning section. I'd just leave out the stuff about Bill LOL!
Have you checked over on the hptuners forums? My cobalt had a 2 bar map but I was at 27psi on an ethanol tune. How much boost are you trying to run? If you need to talk to a tuner who might be able to help out I can pm you the email of my old tuner. Usually he's happy to help if he has time. Granted these are ancient ecus and stuff but back in the day this was what they had and there were cars cranking out ridiculous power on stock computer equipment. It must be doable... Unless every 800+bho car was using megasquirt... Which they very well might.
