Do we need subframe connectors
Originally Posted by philistine
The stock driveline is a 2pc driveshaft for a reason, the angles
I'm planning on measuring my angles this winter also.
The 2pc driveshaft answer is a simple one. Cost, weight, tolerance and packaging. It is much easier to package a two piece shaft because you can make the diameters smaller over the span of the car and it usually has favorable NVH properties compared to a single piece. The two piece also has better articulation and thus will last longer than a 1 piece over the life of the vehicle. (if designed properly....we all know how crap the V center supports are).
Is this ideal for the aftermarket people... no. but generally the OEM's don't give a **** about that.
The reason ford probably went to the carbon shaft is due to the fact that a 1 piece aluminum one wouldn't fit or meet their specs for power, speed rating and proximity packaging.
A Nissan 370Z also has a carbon shaft stock.
Please publish your findings regarding these angles. As a community we should start documenting these angles so we can figure out which motor and transmission mount combos give us the most favorable dirveshaft alinements.
I took my lead from FoMoCo. They saw fit to equip the GT500 with a carbon one piece over the 2 piece that comes in the GT for some reason. The angles your discussing can be corrected....
I'm pretty sure that FoMoCo did that because the GT500 is capable of 200mph+. That would mean the critical speed of the driveshaft would need to be significantly higher. I believe 50+mph because the stock GT is limited to 155mph +/-... Not saying guys haven't gone faster than that in a GT 5.0 stang. I'm just saying, because Ford builds the 500 with the power to do it, they equip it to do it which is kinda nice. Plus it comes from the FACTORY like that. Its setup and designed to be like that, so proper alignment angles are accounted for. Its not hung in there as a replacement. Just something to consider.
Your issue and the issue others seem to have would indicate that is false. Unless the driveshaft is being produced incorrectly... Which it very well may be.
You always tout the reliability of OEM, yet you went aftermarket and are now floating in a sea of issues with the driveshaft. GM designed it to be a 2 piece. Just saying.
To do this, I figured it would make sense to take x measurements from the LF to the RR and the RF to the LR to see how square the car is.
I centered the wheels up front by taking sidewall sight lines (and found my car is fairly toed-in) and getting these sight lines equal on both sides. After this I took the wheels of the car and hung a couple of plumb bobs off the rotors and found that the car is 1/2" out of square.
As fars as being an authority on what I tout, you aren't.
FWIW, Maximum Motorsports has you do the cross measurements like that when installing their K-member (front cross-member) on a Mustang. (Starts on page 7 with "Squaring the K Member".) However, they tell you to hang the plumb bobs from the suspension pick-up points, rather than from the hubs/brakes. That way the alignment and any bushing flex in the control arms is taken out of the equation and you're only measuring the chassis.
Makes sense. The driveshaft is pretty long as a 1 piece. I wonder if having a more heavy duty joint would make a difference. Like a U-Joint, thinking a big *** pickup. They have pretty long driveshafts as well and many have a single section as long or longer than the V. But I'd like to see some solid data either way
#35
Stay with me here. I believe it starts to become plastic-like and then starts pulling apart. Make sense?
Big trucks don't usually do 200 mph.....
Back to the Subframe connectors.
Someone mentioned high horsepower vehicles. Not a really valid point.
ALOT of uni-body vehicles need them at stock levels; think 2nd, 3rd, 4th gen F-bodys and Fox bodies.....
I have had several that NEVER had more than 250 rwhp and they were starting to show signs of sagging in the doors and unibody.
When the front end hits a pot hole, the front goes up and the back does not move, thus moving the point where it bends between the two subframes.....
Same with the rear.
Joining these two frames eliminates these conditions. Period.
Is this necessary for our Vs, not as much.
I was asked to build them, so we did.
They helped my wheelhop alot in certain normal conditions, notwithstanding sliding sideways when it is wet, off camber situations, wet conditions that change road types. lol
With that said, we wee at the track last weekend and we saw MANY vehicles doing burnouts with wheelhop.
It's common and not just a IRS or CTSV phenomena.
Just my .02.
#36
I personally used an aluminum shaft in an f-body that was 55 inches iirc and it worked fine. Don't expect issues with a 60 inch carbon shaft and the fact that there have been reports of successes with shaft confirms it... People report problems before success all day long.
#38
So to sum it up, nobody has had problems with or noticed that their subframe is shifting under load. Further, after really thinking about it, if I cared to straighten it out, I wouldn't see much movement at all in the pinion shaft angle because the cradle is only moving a half inch at most.
Thanks guys...
Btw....I've heard that a carbon shaft turns to dust when it fails instead of turning into a rotating mass of unhappy metal. Don't know if that's true and I hope I never find out....anybody have any experience with this or is that another thread....
#39
lol
Well here is my update...the cradle definitely moves.
I pulled the subframe connectors, the cradle and installed the hardest poly bushings available today.
I got 75D Cradle bushings from RevShift; they are not advertised, but you can get any of their bushings in them. Thy are about equal to solid Al.
LOVED THEM!!!!!
I was expecting tons of noise, especially since my backseat is out and my 10" RF blew a few weeks back, but damn if it is still quiet.
With that said, the cradle does move.
I am also suggesting that if someone wants SFCs for their V, then they need to get bushings and install them first.
The rear end feels so good now. The whine in the stock diff is a little more pronounced, but the clunk in the newest diff is horrid.
Still no hop on dryish ground; concrete.....
LOVED THEM!!!!!
#40
I'm glad I'm not the only one who has a horrific clunk after installing bushings.
The one thing I will say is that, if I'm driving aggressively it seems to be smooth and not clunk at all. If I'm just putsing around it does it pretty bad.
