Loss of power
You know since the car is runnin fine again, i would visit your tune guy.
Probably what happened was after sitting so long it lost its LTFT so it had to relearn thus the loss of power. If you have EFILive of HPtuner, just log the STFT and LTFT and then add that as a % to the MAF, that will help you below 4000rpm. you need a dyno for above 4000rpm...
Dyno can be and should be used for ALL rpm. (steady state tuning) to really dial a vehicle in. (Both MAF and VE if running blend)
Also something to note: you having LTFT on means you are overwriting your top end tune over time. Values are added when LTFTs reach a certain constant count. Id turn LTFTs off if I wanted to keep my top end calibration how I intended it and only run on STFTs. Ive done street tunes and Steady State tuning is easily noticeable with throttle responses, especially where it counts... drivability rpm range. Hope that makes sense.
