engine swap
engine swap
Hey all,
I'm gonna be starting a motor swap tomorrow and I wanna know the fastest way to do this..should I drop the engine and tranny from the bottom, or pull from the top?
opinions differ. I've pulled from the top. see these for more opinions: http://www.cadillacforums.com/forums...-ls6-only.html & https://ls1tech.com/forums/cadillac-...questions.html
From everything I've read. If you have access to a lift, removing from the bottom is the easiest. If you do not, then the top, but you would need to remove the transmission first if I recall correctly.
