3 bar map sensor - eforce
I took the plunge and have an eforce coming. I'll be swapping to LS3 heads for it and plan to run some good boost numbers at least temporary for a standing mile event.
Does anybody know what 3 bar map sensor will fit this? I seem to recall the turbo Cobalts using a 3 bar but I'm not sure if they fit an eforce.
TIA
TIA
You won't see 30 lbs of boost which would require a 3 BAR. My advice would be to use the Cobalt 2 BAR sensor for 04-05 LS6 and use the supplied TMAP with an 06-07 LS2, just change the slope in the calibration.
