who uses wideband o2 setup on their carb motor?
What is the best way to do this? I'm doing a carb'd LQ4 in a fox. I would like a way to at least monitor and preferably datalog the wideband if possible. What are my options and ballpark cost?
TIA
TIA
There have been several threads with people talking about their set ups.
I bought an Innovate LM2 some time ago. I don't have it hooked up full time; I just use it for tuning. The unit is a little pricey and the quite a few people have complained about it being flaky. But in the half dozen car mag comparisons I have read it is always the most accurate and fastest responding.
IMO the data logging is an absolute necessity. Kinda hard to stare at a display at WFO. If you get one that records then having RPM is another necessity. The LM2 has 3 other recording channels available. Lots of guys hook up the MAP sensor from their MSD ignition and some even go so far as to hook up a TPS to the carb. With all that info you can really dial in a carb. The unit comes with free software and SD memory card that allows you to make a run then figure out your trouble areas when you get back home.
Another cheap alternative WB that includes data logging capability is the Zeitronix ZT-2. It's $270ish without a gauge. It logs to internal memory and can be downloaded later (a laptop isn't required to be attached for recording like some setups). It is also a hardwired setup rather than a removable/temporary setup like the LM2 etc.
I like the Innovate Motorsports MTX-L.
It is a simple, self-contained unit that comes with the O2 sensor, all cables and the gauge.
- Hard to get more simple.
Inexpensive also, as you can find them online for around $180.
When tuning technology is this inexpensive, it is hard to justify the reasoning behind not using it.
http://www.innovatemotorsports.com/products/MTXL.php
This is what I'm wondering too. I've only used one on my turbo buick before and have it in the single down pipe. I think FAST makes a stand alone that uses 2 sensors and averages, but not sure. I'm hoping someone else will chime in on this.
In-Zane Moderator
It will help you dial in any engine, efi or carb by allowing you to monitor changes in jetting/fuel from idle to WOT, tuning without one is a thing of the past, you can tune without but there is no more direct route to get a carbed motor performing as close to efi as possible than with a wide band to help you do so.
