Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
ptv clearence
Old 02-12-2012, 01:26 PM
1badeagle's Avatar
Default ptv clearence
Just wanted to show all you guys my ptv clearances on my 6.1 lq4. The clearance was checked with stock gm .054 head gaskets, stock ls3 heads, 4.030 mahle l92 pistons. The cams specs 235/243 .621/.623 110+4.
As you can see, i have a easy. 250" on intake and .230" on the exhaust side. I can tell you that the valves would have hit the pistons if i had not had aftermarket pistons. I am planning on milling .045" of the heads and having them ported as well.
Does anyone know how far you can mill the stock heads before you have issues?
Old 02-12-2012, 01:47 PM
Doug G's Avatar
Been told .060 was max before alignment issues ???? But I would look into deeper
Old 02-12-2012, 01:57 PM
3pedals's Avatar
I know of a set that was cut .070". I am sure the intake bolt hole would need to be ovaled slightly at that point, and maybe small port match work done.
At .050" I had NO intake bolt or port alignment problems. I wont even flinch at cutting .070" if needed to get compression up.
Old 02-12-2012, 03:24 PM
Z284thgen's Avatar
whats it measure if you cut in center of the valve from top to bottom on each one
did the .250/.230 come from the center cut across the intake to exh valve like in pic 1
Old 02-13-2012, 12:38 AM
1badeagle's Avatar
I just measured with a caliber and i have .2665" intake and .221" on the exhaust side.
Old 02-14-2012, 09:28 PM
1badeagle's Avatar
I decided today im going to take the 3pedals route and mill my heads. 050". I want to run a .040" gasket over my. 051" gm gaskets. Who sells ls3 .040" gaskets the cheapest?
Old 02-14-2012, 11:20 PM
jtaylor16's Avatar
this akes me feel really confident going into my cam install 234/238 .650/.650 but with stock ls1 heads, gaskets, and pistons
Old 02-15-2012, 02:53 AM
1badeagle's Avatar
My friend runs a ms4 in a stock ls1.
Old 02-15-2012, 06:37 AM
bitterman's Avatar
Very interesting.... Are those flat tops for the 3.662 stroke and 6.098 stock rods? Or do the pistons require 6.125" rods?
I might think about changing pistons on my ly6 at some point later on and shave the heads for compression too.
Subscribing
Regards,
Bruce
Old 02-15-2012, 08:20 AM
1badeagle's Avatar
Flat tops with 4cc reliefs for a 6.125" rod.
Old 02-16-2012, 06:30 AM
bitterman's Avatar
What did it cost to balance your rotating assembly for the new rods and pistons?
When I decide to take mine apart, I going to do pistons, rods and balance everything, then shave the heads... by then I might also up the cam depending on how thigns go with my current ly6 cam only build.
Bruce
Old 02-16-2012, 06:48 AM
1badeagle's Avatar
I had beech performance build my short block. It was 1000$ to have everything balanced and assembled and set up for a 300hp shot of spray
Old 02-20-2012, 08:11 PM
1badeagle's Avatar
I feel like such an idiot right now. I just realized that i didnt make my lifters solid when i checked my ptv clearances. How much ptv clearence do you lose when you make the lifters solid? Will i still be ok with a .050" mill? I was thinking about milling and running a bit thinner gasket as well like 3pedals is.
Old 02-20-2012, 08:24 PM
jgillen91's Avatar
set you adjustable pushrod checker to the correct pushrod length. then turn engine over. mine needed a 7.325" pushrod that is with .080 lifter preload. i checked ptv clearance with my ls7 lifter preloaded. sounded like the right way to do it in my head but i am sure a solid lifter is desireale
it took 1 3/4 turns to get the torque wrench to click off at 22 ft lbs
1 turn + .047 preload do the math lol
Old 02-20-2012, 08:52 PM
Prorac1's Avatar
I pulled the clip out of one of my factory lifters, pulled the internals apart, flipped the plunger around and assembled the lifter without the spring. Walla.......a solid lifter. Thats how I checked mine. Eric L
Old 02-20-2012, 09:07 PM
twinturbo2's Avatar
what is acceptable ptv clearance i know .100 or is normal anybody run like .070 or is that a little close just wandering
Old 02-20-2012, 09:21 PM
1badeagle's Avatar
Damnit. I wanted to avoid doing the entire thing over again.
Old 02-21-2012, 06:22 PM
Prorac1's Avatar
For p to v clearance i have always heard that .060 on the intake and .080 on the exhaust. Eric L
Old 02-22-2012, 09:26 PM
1badeagle's Avatar
I tried to pull a lifter apart earlier. All i succeeded in doing was having the lifter pop apart and lost pieces. Youguysthink ill be fine with a .050" mill?
Old 02-23-2012, 08:57 AM
Prorac1's Avatar
I wouldnt do anything, no matter how much clearance I thought I had, until I checked. Use a pen magnet to pull the guts out of the lifter cause the little bit of oil in the lifter will try to suck the piston back down. Hope this helps, Eric L
Quick Reply: ptv clearence
