msd 6010 question
yea thats the one I ordered.....and thats why I said they might be using different pics or outdated pics because on Summits site, the link i posted, i typed in MSD 6010 and it went to that page with the same black box......
the Edelbrock box (box in intake Kit 7118 or sumn like that) it is also a red box that only says LS1 controller i think..
That link shows the older LS1/LS6 timing controller which isn't tunable. You can only use the pills.
vs.
The new MSD 6LS which is fully tunable.
See here - http://www.msdignition.com/Products/...)_Engines.aspx
Can anyone confirm which one Autoplicity is selling?
vs.
#34
The black ones are the older versions and even if you find one you're better off not to get it. They have had updates done to them and the red ones are a better box. Some of the earlier versions had trouble firing the plugs unless the starter and battery were extremly strong. If the were even a little bit weak, the motor might start and might not. Not all of them were that way, but it was a common problem. A member(Tosto Racing) had a lot of trouble with his. He had to use two batteries untill he sent it back to MSD for an update.
#38
#40
Just so you guys know the 6010 box is awesome. Easy as **** to tune and dead on accurate with timing. I sprayed 400 on my setup last night and pulled 16 degrees of timing from 26 and the timing mark was dead on on the plug. Plus this box sparks way harder then a pcm or distributor. Cheap as hell and hell of innovation from msd. Save me a lot of money from having to buy a digital 7 spark amplifier distributor and front cover.
