Any regrets for converting to carb?
Ok I'm currious if anyone has regreted swaping to a carb. I've been building a 5.3 S10 and I do have the stock LS1 corvette intake,mass air all complete I've modified the original truck harness to stand alone all that would need to be done is get the pcm flashed and a fuel pump and it be running. Butt...
I'm wanting to convert it to carb ...I dont want to have to buy a tunner,credits,license,or pay someone a fortune just to drive my truck everytime I do a upgrade. I had a DOHC mustang motor I converted to carb and loved it..... me being new to the LS scene I want to get input from guys who have done it already to these motors.
This was my first performance carb project, so yeah, in the initial stages of the learning curve I questioned whether this was the right choice. Took me a couple of years to get it just right. But now that I have the carb pretty well dialed in I have no regrets. Car pulls cleanly in 4th gear from 1200 RPM, has great throttle response and pulls down 25 mpg when driven sanely. Plus I just love the look of the carb and that big Moroso air cleaner.
The MSD ignitions are a dream on these cars too. Very easy to tune and gives us options that simply were not there with the old single coil and mechanical advance dist. I would strongly recommend a wideband O2 if you really want to dial in the carb for maximum drivability. Don't know how guys did it before.
My car is a summer's only project car, so if I had to drive it regularly in cold weather I would probably convert over. I made that worse then it needs to be because I wanted to keep the manual choke.
One thing you can do is go ahead and run an in tank EFI pump with a carb regulator up at the motor. That way you have options should you decide to convert later. A baffled sump is helpful with carb motors too.
when I did the conversion on the mustang it was a blow through turbo set up and I bought a pro systems carb... and it ran great better than the fuel injection.. a few minor adjustments and it was ready to rock and roll ....thats why I wanted to get feed back on the LS1 conversion how good it responds.....my s10 is a none daily driver so starting on a cold morning isnt a factor.
Love my carb'd 6.0...It was about 30 ish degrees here this morning and went outside and she cranked straight up. Get it adjusted right and there isnt any problems. It drives good on the interstate and crazy responsive. BTW, the carb and breather looks better TO ME anyways. MSD box looks cool to control the engine and I love to hear people say man that car is fuel injected huh or how are you controlling it with a carb running it!!! MSD baby....M..S..D!! lol..Did I mention, i like the look of my breather, lol.
Its good to hear ..... I guess I know what direction to go ...just need to get rid of the fuel injection stuff I bought over time so I can get me a carb and intake. I know there are the rules for posting in the for sale section so I wont be able to post it because me being a forum newbie...
I have a complete LS1 intakeW/injectors,throtle body,egr block off,stainless bolt set,mass air sensor,modified 5.3 harness for standalone and LS1 injectors w current performance fuse and relay box and UN-flashed PCM.... I guess off to e-bay it goes anyone have suggestions on what its worth as a package I bought all of it piece by piece for my 5.3 swap.
i got a ls transam and tuned with efi live the tuner fuked up my tune the car went lean and detonated and spun a rod bearing, so now iam goin carb on my car and i will never turn back, and did i mention i drove my car from central new jersey to ocean city maryland for crusing ocean city spring 2012 and she poped there that sucked, fml
I was carbed for three years with my L92 headed LQ4. Worked great. Made a ton of power. I desired more drivability and wanted to add a turbo. So I went megasquirt. Just got it fired. It's weird that you can tell it how to run and it does it. Max power tuning is simple with efi. Drivability tuning is a little trickier.
53, 60, build, carb, carberator, carburetor, conversion, convert, converting, detonation, kit, lean, ls1, lsx, mpg, ms3, work
