Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
LS1 First Fire Idle Speed Too High
Old 10-30-2013, 03:28 PM
79CamaroKyle's Avatar
Default LS1 First Fire Idle Speed Too High
Hello All,
I joined to get some help with my 2008 Silverado 5.3L LC9 Swap into a 1979 Camaro. Rear End 10 Bolt 8.5" ring gear 2.41:1 Positraction. Tranny: 4 Speed Muncie. Holley 750 Vacuum Secondary 3310-3. MSD ignition 6012. Manifold Edelbrock 71187.
Currently having trouble with first fire idle way to high. When I adjust idle speed screw it does nothing.
How do I replace/repair idle speed screw function?
Looking forward to LS1 Tech.
-Kyle
Old 10-30-2013, 07:31 PM
383lt1impala's Avatar
When I started mine it was idleing at 3000rpm I didn't think there was a lot of tension on the throttle cable. But there was. I adjusted it and it's good now. If you bought the carb new call holley.
Old 10-30-2013, 07:46 PM
89gmcs15's Avatar
Check for vac leaks. If its the dual plane manifold there is a bolt that needs to be plugged where they want tou to mound the msd box.
Old 10-31-2013, 05:12 AM
Pop N Wood's Avatar
It should be a simple matter to look at the idle speed screw and butterflies and see if something is hanging up or sticking. There is also a screw to adjust the secondaries, but you need to get to it from underside the carb.
If that is all good and you don't have vac leaks, then you can back off the idle timing to lower the idle speed. That is what I had to do with mine.
Old 10-31-2013, 07:59 AM
I ordered some vacuum plugs. I have two open ports on the bottom side of the Holley and one on the driver side head. I'll plug them and report back.
The Holley is about 25 years old handed down so it may need a major overhaul. I f plugging the vacuum holes does not work I will pull it out and close off the secondary completely to see if that is causing it.
Thanks for the help!
-Kyle
Old 10-31-2013, 08:20 AM
FultonPerformance's Avatar
Sounds like a cool project.. could we get pictures?
Old 10-31-2013, 02:59 PM
I have a bunch of pictures posted at this link:
https://www.facebook.com/media/set/?...1&l=1d648a0113
First Fire Youtube:
Video of Idle Choke Closed:
Old 10-31-2013, 03:15 PM
Some more engine pictures are attached.
File Type: pdf
File Type: pdf
Old 10-31-2013, 07:14 PM
snook's Avatar
Why do you have your hoses ran backwards on the radiator??? Don't see a return spring on the carb??? Ive always had to run one, or they don't go back to home position
Old 11-01-2013, 01:25 PM
I originally had them the other way, I read the forum on here about radiator hook up and switched them. I haven't run the engine more then a minute or two yet due to the high idle. I will switch them back!
As for the spring, definitely need to get one on there. This carb is from the early 80's and I've had nothing but problems with it so far.
Old 11-01-2013, 05:18 PM
snook's Avatar
I thought there might have been a trick I didn't know with the hoses, just wondering. Is it still idling high? Next time it does that, see if it will close by hand anymore
Old 11-01-2013, 10:01 PM
huggerorange69's Avatar
Take the vac. secondary holley and throw it in the garbage and get you a good holley mechanical secondary carb, 750 double pumper, simple and easy to tune, you will thank me later.
Quick Reply: LS1 First Fire Idle Speed Too High
