6010 box map advance with no sensor
I put a new timing curve In the car and forgot to 0 the map advance. .so ive searched and if I read it right tje box thinks its at full vacuum and advances the timing. .so am I running more timing at idle then what I have programmed. Thanks
Answered my question. Sure enough I plugged into the box after work and I had at 0- 10 deg.if I looked at msd it showed it at 16..so it was advancing tje whole curve 6 deg ..I zeroed it out and now it runs at my set timing
