Holley 300-130 Polished and Ported
Spent the last 3 weeks working on this , almost done . Removed the webbing between runners and polished the outside along with a port job inside. Almost done , got to countersink the mounting bolts and polish a few spots better.
Thanks , Guys . Didn't keep track of the time but if I charged someone $10 per Hour I could probably have enuf to buy 3 or 4 new Manifolds. Hardest part was removing the webbing between runners and removing excess aluminum from the runners to make it look right. Then the polishing that still ain't done yet, I'm really **** and it has to be perfect. After I'm happy with the polish then its Clear cote time.
Port alignment didn't look to bad and I didn't open them up too much because the Heads are still stock. I'll address this issue later when I port the Heads , right now I just want to get it running.
