Which carb?
Which carb?
So I just fired up my engine Friday with a used 850 Holley dp and it wouldn't idle. My specs are as follows lq4 bottom end, ported 243s,eps cam 232/246 .607/615, vic jr carbed intake. My buddy and I had problems with this carb on a afr headed 350 a couple of months ago. So I know it's the carb. I swapped it out for a 770 vac secondary Holley street avenger and idled fine but upon revving it wasn't as responsive as 850. I do not know how to tune a carb but plan on buying a wideband soon. Should I just rebuild 850 dp,use the street avenger or call pro systems and let them sort it out? I would rather not buy a new carb because every one will need to be tuned. I want to know what the masses think because it seems the consensus around here for carbed applications is 750 dp. Does any one have a used one for sale to get me started in right direction? Both of these carbs came off of the 350 sbc due to our lack of knowledge and a pro systems carb now resides on it. So what should I do?
Pro systems will get you close, no doubt about that, but they usually need tuning to get them just right.
There is a place called Karb Kings in Pittsburgh that offers a similar service. They will actually rebuild your existing carb. If you sent it to them and tell them in detail what it is doing they could make sure it is mechanically OK.
With your cam and intake an 850 isn't out of the question. General consensus is smaller carbs are easier to tune. Your choice on the 750 vs. 850.
The problem with your 850 could be something like a bad gasket, blown power valve, blocked jet/air bleed, warped base/metering block etc. Something like that could be fixed by rebuilding and checking everything carefully. But it just might be too far out of tune for your motor also.
I agree with your logic on the new carb. You might get lucky and get one closer to being correct right out of the box, but chances are anything you get will need some tweaking. Might as well work with what you have.
Would I be better with street avenger or 850? It seems the vac secondary carb stumbles off of idle and is that typical of a vac secondary carb? I'm confident I can rebuild both but what about a used 750 dp and rebuild that?
Old School Heavy
Once you learn that you will need to make some fine tuning changes to get the carb they way you want it, then you will need some adjustability that the Pro-Systems carbs and the baseline Holley HP carbs just don't have. At that point you will be wishing you had bought a Quick Fuel Q-Series carb. They have all the good parts, replaceable bleeds, emulsion ports and orifices your need to truly tune your carb.
I say get right carb to start with. Get a Quick Fuel Q series and you will have everything you need going forward. I have many say they wish they would have bought one to start with. I have never heard anyone say they wish they wouldn't have bought it.
When the secondary comes in...does it stumble right away or goes then stumble...could be a simple pump shot or squirter size swap ?
I like the DP for max effort cars Vs. a VS for more street friendly stuff.
I will check when I get home for rest of cam specs. Car has 3400 to 3800 coan converter and 3.73 gear. I originally wanted a 4l80e but tired of car sitting. It has been a long process with swap but really put my head down last couple of weeks to get this thing rolling.
