Q? on ECT and Oil Press...
So, what are you guys using for your gauges/sensors. im curious where to run the sig wire to? How can I make a 5Vref for the sensor without running the computer? I assume most the cars on here that are LS swapped are running aftermarket gauges, and you use different senders...but for the people using stock gauges in 98-02, what do you do? also for the oil pressure as well.
I dont know of anyone that has done that yet with the stock guages for the 98-02 F-Body but if you find someone that has link them here because there are a few of us that have 98-02 carbed F-bodies.
