Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Where should my compression be at ?
Old 04-09-2015, 07:35 PM
1973 STEP A SIDE's Avatar
Default Where should my compression be at ?
How much compression should my 5.3 be at ? This is what I have .
1 150 psi
3 150 psi
5 150 psi
7 150 psi
2 147.5 psi
4 145 psi
6 147.5 psi
8 147.5 psi
Old 04-10-2015, 04:41 AM
Doug G's Avatar
Not knowing combo, cam overlap, and such...guessing stock comp. with a slightly larger cam ?
I'm sure there is some formula out there ???
Old 04-10-2015, 07:38 AM
Old School Heavy
speedtigger's Avatar
Consistency is generally what you look for when the engine specs are not known and your numbers are all very consistent.
Old 04-10-2015, 06:34 PM
dogsballs's Avatar
As above, same or similar across cylinders
Old 04-12-2015, 05:37 PM
As always Thanks !!!
Old 04-15-2015, 01:08 PM
RabidStreetRacer's Avatar
http://www.rbracing-rsr.com/compstaticcalc.html
This site will get you your static compression ratio.
You need to know your Cams ABDC number to calculate your dynamic compression ratio
Old 06-02-2016, 10:02 PM
Kloeppel's Avatar
I have a ls3 427 stroker with 11:1 compression and I just did a compression test and it was does this sound ok? Thanks
130
125
125
120
125
120
110
Quick Reply: Where should my compression be at ?
