View Poll Results: et predictions? I am goinf out Saturday. Temp will be highs in 60s, lows in 40s.
a-5.9? or , b - 6.0s
2
66.67%
c-6 teens d- 6.2s
1
33.33%
Voters: 3. You may not vote on this poll
new build....
I might tend to agree if it was a max effort deal. But I'm willing to put money in this thing being quicker. The weight loss, compression gain and cubes, even tho it's only 12 cubic inches, will be quicker.the valves will be unshrouded, which so many have said is a problem with Ls3 heads on a 6.0. Although it's not much, I don't see how 065 can help unshroud the valves much. Lol
Old School Heavy
Lets say that we accept the idea as true that the bores are more rigid and stable in the iron block. The question then becomes how much right? How much more power would sneak past the rings of an LS3 block versus an LQ4 block?
Then we have to consider how that compares to 12 more cubic inches, valve unshrouding, 100 pounds of weight loss and the .32:1 extra compression that he gets with the LS3.
The extra displacement is worth about 19-20 horsepower at 1.65 hp/ci. The hundred pounds is the equivalent of 10-15 HP at his power to weight ratio? The unshrouding and a few horsepower for the extra compression too.
So, you would be suggesting that 35-40 horsepower or so will be leaking past the rings on his LS3?
I like the math for the LS3 myself.
Just a thought here Steve...
You have gone out of your way to to amass a list of the fastest SBE cars and what they run or seem to make for powe.r
Of the fastest cars YOU have claimed see to make in your words, extra ordinary power, i believe they were/are all 6.0 iron block combos????
Hmm..............
I'm not saying his car wont run faster, i just don't put the same merit in the 12 cubes, and shrouding problem that you are is all
Hell look at your heads, they seem to work on a small bore just fine
Hmm..............
Old School Heavy
Have you seen evidence that the LQ4 iron block's cylinder seal up better than the LS3? I don't doubt that is the case, I just haven't seen any tests on that.
I know with my own stuff the difference in oil I was/am getting out of breather tank compared between alum alloy and iron block
Also some other little things I have noticed that I feel are contributed to a better ring seal IMO
old motor was 9.6 stock compression, with heads milled .020, this motor stock is 10.5 and the heads will be milled 050. I am just hoping the suspension is more forgiving with the weight off the nose. The car is working pretty good, but this cant hurt. I will keep you all posted. The heads I am hoping will be done today. Maybe I can get pistons notched and heads assembled to get this thing put in this weekend. If so, we will probably have it out next weekend.
You may have to take some spring rate out of the frt end as well if its a coil over setup?
When I went with my Ls3 block I def noticed the car was more forgiving on certain tracks, but I regret not working on car more with the iron engine as I felt it made more power !!!
#32
#37
And current 09' Ly6 iron block-makes about 40-45hp more on Nitrous than old N/A combos did up here
#38
Did a little search....HERE THEY ARE.
#39
7.250 (with stock .051 gasket, LS7 lifters) and not off the top of my head.
#40
Turns out I had 7.350 pushrods in my old motor, they was a little off in my preload, but I thought I would try them. preload was at .043. Motor sounds good. It sounds a bit more powerful, and during the drive, it pulls hard. I didn't turn on the shift light, but when you mash it, it goes! It seems you can tell there is less weight on the nose, it just feels different. It does seem like I will need to change coil over springs in the front. The front feels like it did with iron block and 14x175s with the current aluminum block and 14x130s. But we should have some time slips to see this week.
