Need Help Camaro Throwing Code P0101
A buddy of mine has a 99 Camaro Z28 and it sounds like its misfiring real bad it threw the code P0101 Mass Air Circuit/Range Performance if someone could help me on this i really appriciate it.
Hope this helps you some. Seems like the problem is the maf.Has your friend done any work to the car recently? I'd check the screen in the maf to see if it's clogged, make sure the plugs are in and the wiribg is in good shape, and last since you also have a camaro ls1, swap your maf into hi car to see if the problem goes away.
Good luck and let us know if the issue is resolved and what the solution was.
