Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
fitting a 325/50/15 on 67 camaro.. help please
Old 10-26-2009, 02:52 PM
nesluopetan's Avatar
Default fitting a 325/50/15 on 67 camaro.. help please
I want to fit a 325/50/15 ( 28" ) in my fenders without rubbing on the lip or frame. i am going for the pro street look and want to slightly tuck the tires up in the fenders without rubbing. I just ordered my moser 9" and had it shortened 2" on each side. 35 spline, wave trac & 4 piston brakes and it finally shown up on friday.
I am also going with a mini tub kit that will let me fit a tire to my frame rail and I am also running a 4 link setup so there is no leaf spring to worry about. i am really bad with figuring out wheel sizes and all that so I want to make sure I order the right parts. I am going with factory replaca rally rims and I notice on summit they sell vintage replace rallys that are 15x10 with 5" and also with 5.5" backspacing. Would either of these work, or would I have to order a custom back space? I would just like your opinions of what I need to do to complete this task.
I am almost done with my entire twin turbo 540 build and this is the last thing that I need to do before I tune it. It has been a 2 year project in the making and it's finally all behind me except this last wheel / tire issue. Thank you for all your help and I hope to check this site out quite often !
Please let me know what you all recommend and I will order up what I need so I can finally finish my car! Thanks again, from Utah!
Old 11-09-2009, 09:25 PM
dHud's Avatar
Shortened 2" on each side from the factory camaro width? If so(this is just my figuring, dont take it to the bank), a 15x8 uses a 4 1/2 bs(stock width rear end), if you go 15x10 you would need 2" more bs(stock width) which would be 6 1/2" bs, but you're 2" narrower so you'd bring it back to 4 1/2" bs..................I think
Old 11-21-2009, 08:14 PM
stroker_SS's Avatar
Did he say TWIN turbo 540.......I hope you have good life insurance.
Old 11-29-2009, 04:43 PM
DionM's Avatar
Man what a great looking car. Can't wait to see it with the mini tubs and stuff.
Dion
Quick Reply: fitting a 325/50/15 on 67 camaro.. help please
