New thought for my camaro
what are the possibilities of running true duals over axel like the vettes, know let me ask you guys... what are the possibilities of using a corvette exhaust on a camaro 1999 with an ls1
check on thirdgen.org, people have had ideas like this and the bottom line is you run into fittment issues over the axle, the only thing you can do is run the pipes alongside eachother down the passenger side frame, then put them up over the axle and then turn them to the center once you get it behind the axle
pacesetter sells a true dual system, my buddy has it on his GTA
actually just wanted to do it over the axle i have the true dual dump before the axle and wanted to get a c5 vette exhaust probably a aftermarket run it over the axle and into my cme valance
