Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
97 z28 cooling fan issue
Old 12-09-2012, 10:20 AM
mutlyi4's Avatar
Default 97 z28 cooling fan issue
ok so ive had this car about a month my first lt1 car my issue is my radiator cooling fans have no high speed they come on in low just fine i have pulled them and hotwired them they work great just not through the cars electrical system not sure where to start is there a high speed relay or does anyone know what could cause this also i have replaced the coolant temp sensor in the water pump to
Old 12-13-2012, 05:03 PM
mutlyi4's Avatar
does anyone at least have a wiring diagram??
Old 12-15-2012, 08:26 PM
mildensteve's Avatar
Here is a thread I found while researching a similar problem. https://ls1tech.com/forums/stereo-el...ling-fans.html
Come to find out after searching and chasing wires, the car runs hot from the factory and you need to get the PCM redone in order to change the fan on temp setting or hard wire the fans. Good luck.
Quick Reply: 97 z28 cooling fan issue
