LT1 Coolant Bleeding
I have a question about bleeding the coolant in my '95 z28. I've been having an overheating problem that I suspect to be the water pump but before I swapped that out I wanted to bleed any air out of the cooling system in the hopes that was the problem. My coolant level is right on the money according to the stick but I don't see any coolant under the cap after running the engine much less getting an overflow. When flushing the system are you supposed to add that much over or is something wrong here? I took my thermostat out, too, by the way.
