6.0 ls3 heads
6.0 ls3 heads
I am starting to gather parts for ls swap into my 67 Camaro. I have a 2008 6.0 out of hybrid tahoe and a set of new ls3 heads. I work for GM at chevy dealer here in olympia so I have got a few ls3 parts, tb maf and wp. I am planning on doing ctsv serp setup on it and run a stock ecm with stand alone harness. Planning on 4l65e for trans and hp tunner to delete rear o2 and vats. What camshaft would you suggest for this build I am shooting for 550-600 fwhp. Any thoughts or ideas for build would be appreciated.
So this is one cam I like
Comp Cams 277LrRHR-13
RPM Range: 1900-7000
Duration: 277 deg. Intake / 293 deg. Exhaust
Duration at .050": 227 deg. Intake / 243 deg. Exhaust
Valve Lift: .614" Intake / .624" Exhaust
Lobe Separation: 113 deg.
