Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Need to replace front door speaker, monsoon system, 02 z28 camaro. From 4 wire to 2
Old 07-25-2013, 07:56 PM
darkshadow290's Avatar
Default Need to replace front door speaker, monsoon system, 02 z28 camaro. From 4 wire to 2
Want to replace the 2 ohm front door speakers with Alpine sps-610 coaxial 2 way speaker system 80 watts rms. How do I do it but still hook to the monsoon factory amp ?
Old 07-26-2013, 09:23 PM
GaryDoug's Avatar
I did something similar when I wanted to replace the original door midrange (decayed) speakers. I just wired the new coax one as usual and clipped a wire from the new tweeter to disable it. Or instead you could just unplug the old tweeter. I didn't like the loss of volume though, as mine were 3.2 ohms and naturally didn't have as much sound as the original 2 ohm ones. I had to adjust the balance off center to keep it sounding right. I later found some OEM Delco 2-ohm replacements and went back to using them.
Quick Reply: Need to replace front door speaker, monsoon system, 02 z28 camaro. From 4 wire to 2
