My 69 Camaro LS swap parts list and issues.
Hey Everyone
I thought I would share this list in the hopes that it helps others in this forum. I had a 69 Camaro with a non-stock 307 and powerglide, both were very worn out. I swapped in a LQ4, I did not even crack open the engine, except for topping it off with a carb, I just left it stock for now.
Below is a parts list for swapping the engine along with a 700r4. I also have notes next to parts that had issues, usually fitment. As for what I spent, Engine and all the parts under that heading; $6000, transmission and parts; $2400. I do not have a carb listed because I already had one so you need to add that to your list.
Engine
2003 LQ4 6.0L engine 112k miles
Holley LS retrofit oil pan – Using stock height motor mounts, pan hit frame. I raised the engine 3/8 inch using a second set of Holley LS swap plates
RPM performer LS1 intake
2010 Camaro water pump
2011 Camaro belt tensioner
Dynotech Headers – Fit great but are touching the transmission bellhousing.
Dynotech exhaust
Holly LS engine swap .5 in forward – needed to move engine forward to clear firewall. 1 inch forward would have been better, small block heater hoses may be able to be used.
Holley LS mount plate HOK-12611HKR – used to raise engine, see above
Energy suspension motor mount – only mount that will fit with the Holley LS swap plates. Normal motor mounts will not work because of an elongated bump on all that I could find.
Edelbrock fuel pump
Fuel filter
Fuel pump relay kit
MSD ignition controller 6010 – I had a problem with the wiring harness, leads to the cam and crank sensors were too short. The harness could reach one or the other but not both at the same time. I soldered in about 3 inches to the cam sensor.
MSD LS1-6 spark plug wires
Dipstick tube
Intake manifold gasket
Valve cover gasket
Fuse block with cover
Battery terminal
Aluminum radiator w/ dual fans – bought off of ebay, problem with inlet/outlet sizes. See splicer sizes below.
Dual fan harness
Hose splicer 1.5 to 1.75 & 1.25 to 1.5
Radiator hose 8814
Radiator hose 9070
Throttle bracket spring kit
Fuel line hose 4 ft
fuel line hose 3 ft
fuel line hose 8ft
Heater hose
Muffler cement
PS resevoir
Power Steering pump
LSx accessory bracket from Kwik performance, worked perfectly.
1/8 in.NPT to 16mmx1.5 male Oil adapt.
200 deg ON, 185 deg OFF switch
6 AN 10 feet hose
6AN 90 deg hose to female x 3
5/8-18 male to 6AN male X 2 – I had to make my own power steering lines to match the modern PS pump to old steering box.
6AN to 16mm x 1.5
1/2 tube flare w/11/16-18 male to 6AN
Transmission
700r4 Transmission w/ torque converter, fill tube, dip stick, TV cable, lockup wiring kit
GM replacement shift cable
Shifter conversion kit
Shift detent
700R4 cooling lines
700r4 crossmember
Flexplate 168 tooth
Driveshaft - shorten and rebuild
Engine
Dynotech exhaust
Edelbrock fuel pump
Fuel filter
Fuel pump relay kit
Dipstick tube
Valve cover gasket
Battery terminal
Dual fan harness
Radiator hose 8814
Radiator hose 9070
Fuel line hose 4 ft
fuel line hose 3 ft
fuel line hose 8ft
Heater hose
Muffler cement
PS resevoir
Power Steering pump
6 AN 10 feet hose
6AN to 16mm x 1.5
Transmission
Shift detent
700R4 cooling lines
700r4 crossmember
Flexplate 168 tooth
Price was the deciding factor. Yes the 700r4 is not computer controlled, a 4l65e was about $500 more without the computer and a computer costs $700 - 1000. If I had the money I would have went electronic because I would have had more control over shift points and firmness. The 700r4 uses a TV cable for adjusting those but it is diffucult to get correct.
Im doing an LS swap as well on my 68 and also using the fresh 700R that I installed last summer. Did you use the stock 6.0 intake or did you have to replace it with a carb and intake. Im didn't see it on your list?
In my list I have the RPM performer LS1 intake and MSD ignition controller 6010 for converting to carb.
I think you will have a difficult time trying to properly connect and adjust the 700r4 TV cable to anything other than a carb. The geometry has to be correct.
