Turning a 98 into a 99!! Need Help
Ok so some idiot in a jaguar hit me in my 99 z28 m6 and now it is beyond repair(at least not cheaply). So i bought a 1998 z28 shell that is missing the engine and transmission along with the wiring harness and pcm. Does anyone know what it will take to make everything function properly. I need to know mostly differences in wiring like if the chassis harness is different in 98 and 99. Also i heard that in 99 they went to a bosch abs unit. Just any little thing will help. if i have to i will switch out all the vehicle wiring and components but i would like to know what is really necessary to change out. Thank you
Does anyone know what it takes for the 1998 cluster to read the temp on the 99 engine and electronics (wiring + ecu). Can it be added separately if you cant get it to work. I just need it functioning but i would prefer it actually tell me the temp like the 98s do.
