F body full frame?
F body full frame?
Has anyone put a full frame to there subframe f body for dragging? If so what are some of the requirements that go along with it. Also tubbing the rear end. Just trying to get an idea. I have a 95 z28 and 2000 that I'm debating on between the two on which one to turn into the drag car
A better question is how fast do you plan to run? That will determine the minimum of what you will need to do tech requirement wise.
To answer the original question, you can build a tube chassis from scratch or using kits from S&W, Jegster, Chris Alston's Chassisworks, etc. It's extremely fabrication intensive and not really something I'd do if you're just starting out with racing.
