Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
confused???
Old 11-01-2014, 04:24 PM
nazztman4739's Avatar
Default confused???
OK I'll start with this because I have had 2 LS based f bodies same problem so must be common , OK so first to fill my car with fuel and a previous car I owned 02 and 99 camaro it took forever I mean u couldn't even go to the first click on handle.right after that started happening the car now will run great u will stop for a couple mins and it will just crank over won't start I have a snap on solus no mil everything seems to be looking good just won't start
Old 11-01-2014, 04:27 PM
Oh and yes it is getting fuel
Old 11-01-2014, 10:23 PM
Chevyman1968's Avatar
Don't know if this can happen. But the vent to the tank is possible clogged. This will cause the tank not to fill up properly and It may (may) cause some kind of vapor lock. Which will not all the pump to pick up the fuel properly. Not sure maybe someone that has had that problem can chime in.
Old 11-01-2014, 11:37 PM
Fry_'s Avatar
Don't know what is causing that but I'd put money on it not being an internal engine problem. So why is it posted here?
Old 11-02-2014, 07:46 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Excellent question. My answer is that's why it's moved to The Camaro section.
Old 11-02-2014, 08:12 AM
Ty Chevy man i actually was thinking the same thing and there's a valve next to tank I was wondering if that's what could be doing it it will cause a slow fueling problem but can they be connected since I have owned 2 cars same issue by
Quick Reply: confused???
