doesnt run like it's supposed to :( need help!
hello i need help, i just fixed my car from a wreck its a 98 ss 6 speed and it doesnt run like i thought it would, i step on the gas and it takes off slow then starts to catch speed and i dont know what else to check everything seems to me in place but just that problem that it doesnt take off like it should, any help will be appreciated.
Maybe something happen to the computer. Try getting a tune or at least looked at
Take off the bellow from the throttle body to the air lid. Have a friend step on the gas till it's floored (obviously the car has to be off). Make sure the throttle is opening all the way. Maybe during the wreck the throttle bracket was bent and there is now excessive slack in the cable.
If there is a tuner local that could log some time on the car and give you an idea what it could be but checking the throttle blade is a good idea. Pull a couple of plugs and see what they look like. Does the car have cats? That is something else to check. Usually can tell by the temperature if they are plugged.
