My 2000 Z28 Build
My 2000 Z28 Build
ok so this is for my 2000 Z28 A4 its currently putting 317 rwhp however speed and power is addicting so this is what i intend on doing over the course of the summer hopefully it will be ready by june...
Project Lilith Part Breakdown Guide
Location Part Price
Body
RK Sport Grille $135.95
Harwood 2.5" Cowl Hood $517.75
SuperSport Style Spoiler Wing $192.50
blk drl led halo rim projector headlights $109.00
gtr fender $185.03
total $955.20
Suspension
Panhard Relocation Kit $89.85
Shock Strut Tower Brace $46.85
lower adj control arms poly/swivel join combination $109.32
round tube subframe connectors weld in $108.62
Founders adjustable tranny mount torque arm $234.85
stranoparts 35/22mm hollow sway bar set $339.99
BMR performance torque arm relocation kit $239.95
koni shock str t series front $184.00
koni shock str t series rear $172.00
umi performance front end kit stage 2 $1,259.00
ls1 k member r r $80.00
tubular lower a arm set street
tubular upper non adjustable upper a arm set chrome moly $150.00
total $3,014.43
Power
texas speed true dual exhaust $409.99
FMS ported oil pump $115.99
ls2 timing chain set $109.99
ls7 lifters $124.97
retro fit rocker arm trunion kit $129.00
ls7 lifter tray set of 4 $31.80
platinum spring kit with titanium retainers $299.00
fast toys clear 104mm high flow air lid $199.50
Super sucker ram air kit jaws edition $199.00
yank super stock 3600 stall torque converter $719.99
hawks 450 rwhp kit $4,295.00
deluxe heads & camshaft bolt & gasket kit $422.99
160 degree thermostat $47.99
motive 3.42 gear ration series 2 carrier $239.99
Powerbond Underdrive Pulley Kit for F-Body $229.95
High Output Alternator $192.00
Burkhart Chasis Front Bumper Support $254.00
Firebird Leather Seats Front and Rear $650.00
Transgo HD2 Shift Kit $77.97
total $8,749.12
Grand Total $12,718.75
so if its possible id like some input do you think this will get me anywhere near 500 rwhp what would you change.... im also kicking around the idea of refreshing the engine and transmission while all the stuff is down what would you say is not needed or not a priority right now? im thinking of dropping some of the suspension stuff and not to mention this is going to be a DD also i want to keep it all N/A power at least for now
Location Part Price
Body
gtr fender $185.03
total $955.20
Suspension
total $3,014.43
Power
ls7 lifters $124.97
total $8,749.12
