replacing rear differential fluid on 99 camaro SS 6MT?
How do I replace the rear differential fluid on a 99 Camaro SS 6 speed?
Do I need to remove the 10 bolts on the differential cover for it to drain, or is there a drain plug?
Do I need a new cover gasket?
Also how can I tell if I have an Auburn or Torsen differential?
If it's the stock cover there is no drain plug, loosen the bolts and let the fluid drain out. Yes you need a new gasket. I put a little gasket sealer on both sides of the gasket, put the cover back on but don't tighten all the way, let it set up for a half hour or so then tighten down.
On the passenger side of the unit you will see a 3/8 drive bolt that you can just unscrew with a ratchet to fill till it comes out of that hole
a torsen will be very obvious, it will have only worm wheels and worm gears, no clutches. somewhat like this but i didnt get a great picture of the inside
if you have it open, spin one wheel and you will see the wheels and gears turning but the other wheel will not spin.
