AIR Pump Problem
AIR Pump Problem
Just recently, my check engine light kicked on on my 02 SS. The code I'm getting is P0410B (Secondary Air Injection....). The AIR Pump appears to be working normal and I can't find any leaks so I'm a little unsure as to why the computer is recognizing this as a problem. Any suggestions? Thanks!
If the pump is working I assume the AIR PUMP fuse and relay are OK, those are the first things to check. Could be both air check valves are clogged or there is some other restriction in the system somewhere. Here's the diagnostics: www.gearchatter.com/viewtopic9356.php
