lq4+powerglide...
Old 10-19-2008, 11:21 AM
grandporschegt's Avatar
Default lq4+powerglide...
i am planning to swap a lq4 into my datsun drag car. it currently has a glide bolted to a 355 sbc. what does it take??? what flywheel would i use? thanks in advance...
damn it could a mod move this to the right section sorry i am a newb!
Old 10-19-2008, 11:45 AM
pic of said beast, if ugly means it is fast then i am set..
Old 10-19-2008, 02:55 PM
magic's Avatar
The powerglide bellhousing will bolt up....
There are some differences with flexplate and torque convertor....some companies make a torque convertor to bolt up to the LSx style flexplate or a flexplate/spacer to bolt up to the existing torque convertor...
Old 10-19-2008, 03:01 PM
i supose buying the new flewplate would be cheaper as converters are spendy...
Old 10-19-2008, 07:15 PM
Shawn MacAnanny's Avatar
It's a spacer that you will need to 'space' the converter from the flywheel. it requires longer bolts and for you to 'oval' the holes of the ls1 flex plate. All you bolt holes will line up except one up top i believe and the LS1 will have an extra bolt hole.
Old 10-19-2008, 07:16 PM
69importkilla's Avatar
Check with GM, they make a spacer specfically for doing this. I'll chime back in if I can find the part number.
Old 10-19-2008, 07:53 PM
350SS's Avatar
LS1 Flexplate Spacer 12563532
http://www.crateenginedepot.com/stor...2-P1343C0.aspx
LS1 Flexplate Spacer Bolt 12563533
http://www.crateenginedepot.com/stor...3-P1344C0.aspx
Though the LQ4 will probably already have this installed since the 4L80 is used behind it and requires the spacer setup.
Old 10-20-2008, 02:43 PM
you sir, are the man!!
thankyou!!
Quick Reply: lq4+powerglide...
