What did you jet your Carb? COME ON IN!
List the size of your motor, heads, aprox. cam size, manifold, carb you are running, fuel octane, timing, jetting and nozzles. Lets see all the different combos out there and maybe help others get a ball park for tuning.
1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam,victor JR intake, Demon 750DP, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
I dont have the Demon 750 setup yet.
Old carb was Hollley 750 vacuum secondary carb, 72 priamries, 76 secondaries, 4.5pv worked the best, #34 (around there) squirter, 50cc acclerator pump with red cam.
Running 15 degrees base timing with 10 degrees advance with max of 28 degrees at WOT using the MSD 6010 box with a map sensor. Ides at about 25 degrees timign and 750 rpm.
