Pin-outs for 2007 truck harness...
Hey all, I'm putting an LQ4 from a 2007 Chevy 2500 HD into my old Jeep. I'm not afraid of doing my own harness, but I don't want to buy $130 worth of field service manuals to do so...
Does anyone know somewhere online where I could get access to the pin-outs and/or wiring diagrams for this year/model of pickup?
Thanks!
Jake
Thanks!
Jake
www.alldatadiy.com... You can buy a 1 yr sub, for about $30.00 LOTS of good info, and it can be printed out.
1 Post
This link might help as well, depending on how much is common between the LQ4 & the L92... (I'd think that GM would try to standardize as much as they're able to, but I certainly wouldn't bet everything on it...)
Good luck.
Good luck.
here is the first connector at the PCM. Give pin #, then color, then circut, then function...Should tell you where everything goes
Description: 73-Way F Receptacle 0.64 2.8 Sealed (BK)
Engine Control Module X1 Pin
Wire Color
Circuit No.
Function
1
0.35 OG/BK
1786
Park/Neutral Signal
2
0.5 GY/BK
1694
4WD Low Signal (NQG/NP2)
3
0.5 TN/WH
1695
Axle Switch Signal (NQG/NP2)
4-8
Not Used
9
0.5 L-BU/WH
6311
Brake Switch Signal
10
0.5 PU/WH
1668
HO2S High Signal - Bank 1 Sensor 2
11
0.5 TN/WH
1669
HO2S Low Signal - Bank 1 Sensor 2
12
0.35 OG/BK
380
A/C Refrigerant Pressure Sensor Signal (CJ2/C67)
13
0.35 TN
5514
Low Reference (CJ2/C67)
14-15
Not Used
16
0.35 PU
1589
Fuel Level Sensor Signal - Primary
17
0.35 D-BU/WH
473
High Speed Cooling Fan Relay Control (-LY6)
18
0.5 D-BU
5985
Accessory Wakeup Serial Data
19
0.5 PK
439
Ignition 1 Voltage
20
0.5 RD/WH
440
Battery Positive Voltage
21-22
Not Used
23
0.35 PU
1272
Low Reference
24
0.35 D-GN
890
Fuel Tank Pressure Sensor Signal
25-26
Not Used
27
0.5 TN/BK
2501
High Speed GMLAN Serial Data Bus-
28
0.5 TN/BK
2500
High Speed GMLAN Serial Data Bus+
29
0.35 D-BU
1161
APP Sensor 1 Signal
30
0.35 BN
1271
Low Reference
31
0.35 TN/BK
6049
Low Reference
32
0.35 L-BU
1162
APP Sensor 2 Signal
33
0.35 GY
2709
5-Volt Reference 1
34
0.35 GY/WH
2700
5-Volt Reference (CJ2/C67)
35
Not Used
36
0.35 TN
1274
5-Volt Reference 1
37
0.5 TN/BK
472
IAT Sensor Signal
38
0.5 TN
2760
Low Reference
39-40
Not Used
41
0.5 YE
492
MAF Sensor Signal
42-46
Not Used
47
0.5 PK/BK
1339
Ignition 1 Voltage
48
Not Used
49
0.5 TN
1671
HO2S Low Signal - Bank 2 Sensor 2
50
0.35 D-GN/WH
465
Fuel Pump Relay Control - Primary (LGM/LY6/LC9)
Fuel System Control Module Signal (-LGM/LY6/LC9)
51
0.35 TN
1465
Fuel Pump Relay Control - Secondary (LY6)
52
0.5 YE/BK
625
Starter Enable Relay Control
53-55
Not Used
56
0.35 WH/BK
1164
5-Volt Reference 2
57
0.35 YE/BK
1827
Vehicle Speed Signal
58
0.35 D-GN
335
Low Speed Cooling Fan Relay Control (-LY6)
59
0.35 YE
5991
Powertrain Relay Coil Control
60
Not Used
61
0.5 WH
1310
EVAP Canister Vent Solenoid Control
62
Not Used
63
0.35 D-GN/WH
459
A/C Compressor Clutch Relay Control (CJ2/C67)
64
0.5 OG/WH
3223
HO2S Heater Low Control (Bank 2 Sensor 2)
65
0.5 GY/WH
3122
HO2S Heater Low Control - Bank 2 Sensor 1
66-67
Not Used
68
0.35 BN/WH
419
MIL Control
69
0.5 PU
1670
HO2S High Signal - Bank 2 Sensor 2
70
0.35 L-BU
1937
Secondary Fuel Level Sensor Signal (LY6)
71
0.5 PU/WH
821
VSS High Signal (20/30 Series +NQF/+NQG/+NP2)
0.35 OG/BK
6399
Replicated TOS Signal (10 Series/20/30 Series -NQF/-NQG/-NP2)
72
0.5 L-GN/BK
822
VSS Low Signal (20/30 Series +NQF/+NQG/+NP2)
73
3.0 BK/WH
451
Ground
Here is the second PCM connector......................................... .......
Description: 80-Way F Receptacle 0.64 2.8 Sealed (GY)
Engine Control Module X2 Pin
Wire Color
Circuit No.
Function
1
Not Used
2
0.35 PU/WH
6270
5-Volt Reference 2
3
0.35 GY
2701
5-Volt Reference 2
4
Not Used
5
0.5 BN
582
TAC Motor Control - 2
6
0.5 YE
581
TAC Motor Control - 1
7
Not Used
8
0.5 D-GN/WH
428
EVAP Canister Purge Solenoid Control
9
0.5 GY
5493
Cylinder 6 Shutoff Solenoid Control 3 (-4.8L)
10
0.5 D-BU
5491
Cylinder Shutoff Solenoid Control (1) (-4.8L)
11
0.5 OG
5494
Cylinder 4 Shutoff Solenoid Control 2 (-4.8L)
12
0.5 GY/WH
3113
HO2S Heater Low Control - Bank 1 Sensor 1
13
0.5 L-GN
3212
14
0.5 L-GN/BK
5492
Cylinder 7 Shutoff Solenoid Control 4 (-4.8L)
15
Not Used
16
0.35 PU
5284
Camshaft Actuator Solenoid Control (6.0L/6.2L)
17
0.5 D-BU/WH
878
Fuel Injector 8 Control
18
0.5 TN/WH
845
Fuel Injector 5 Control
19
0.5 YE/BK
846
Fuel Injector 6 Control
20
0.5 TN
1744
Fuel Injector 1 Control
21
0.5 YE
410
ECT Sensor Signal
22
0.5 TN
2761
Low Reference
23-25
Not Used
26
0.8 D-BU
496
KS 1 Signal
27
0.8 GY
1716
KS 1 Signal
28
Not Used
29
0.8 L-BU
1876
KS 2 Signal
30
0.8 GY
2303
KS 2 Signal
31
Not Used
32
0.5 GY
23
Generator Field Duty Cycle Signal
33
0.5 BN
1174
Oil Level Switch Signal
34
0.35 BK
2755
Low Reference
35
0.35 TN
2752
Low Reference
36
Not Used
37
0.5 L-GN/BK
1745
Fuel Injector 2 Control
38
0.5 PK/BK
1746
Fuel Injector 3 Control
39
0.5 L-BU/BK
844
Fuel Injector 4 Control
40
0.5 OG/BK
877
Fuel Injector 7 Control
41
0.35 GY
2705
5-Volt Reference 1
42
Not Used
43
0.35 GY
2704
5-Volt Reference 1
44
0.35 D-BU
6259
5-Volt Reference 1
45-49
Not Used
50
0.35 TN/WH
331
Oil Pressure Sensor Signal
51
Not Used
52
0.35 TN
2199
Low Reference (6.0L/6.2L)
53
0.35 OG/BK
469
Low Reference
54-55
Not Used
56
0.5 TN
1664
HO2S Low Signal - Bank 1 Sensor 1
57
0.5 PU/WH
1665
HO2S High Signal - Bank 1 Sensor 1
58
0.35 L-GN
432
MAP Sensor Signal
59
0.5 PU
1666
HO2S High Signal - Bank 2 Sensor 1
60
0.5 TN
1667
H02S Low Signal - Bank 2 Sesnor 1
61
0.5 BN
25
Charge Indicator Signal
62
Not Used
63
0.35 PU
486
TP Sensor 2 Signal
64
0.35 D-BU/WH
6265
CMP Sensor Signal
65
0.35 D-GN
485
TP Sensor 1 Signal
66
0.35 BN
6266
Low Reference
67
Not Used
68
0.35 WH/BK
6271
CKP Sensor Signal
69
0.35 GY/BK
6272
Low Reference
70
0.5 PU
2121
IC 1 Control
71
0.5 PU/WH
2128
IC 8 Control
72
0.5 OG
2127
IC 7 Control
73
0.5 OG/WH
2122
IC 2 Control
74
0.5 L-BU/WH
2126
IC 6 Control
75
0.5 D-GN
2125
IC 5 Control
76
0.5 D-GN/WH
2124
IC 4 Control
77
0.5 L-BU
2123
IC 3 Control
78
0.5 BN
2129
Low Reference
79
0.5 BN/WH
2130
Low Reference
80
Not Used
Wire Color
Circuit No.
Function
1
0.35 OG/BK
1786
Park/Neutral Signal
2
0.5 GY/BK
1694
3
0.5 TN/WH
1695
4-8
Not Used
9
0.5 L-BU/WH
6311
Brake Switch Signal
10
0.5 PU/WH
1668
11
0.5 TN/WH
1669
12
0.35 OG/BK
380
13
0.35 TN
5514
14-15
Not Used
16
0.35 PU
1589
17
0.35 D-BU/WH
473
18
0.5 D-BU
5985
19
0.5 PK
439
Ignition 1 Voltage
20
0.5 RD/WH
440
21-22
Not Used
23
0.35 PU
1272
Low Reference
24
0.35 D-GN
890
25-26
Not Used
27
0.5 TN/BK
2501
28
0.5 TN/BK
2500
29
0.35 D-BU
1161
APP Sensor 1 Signal
30
0.35 BN
1271
Low Reference
31
0.35 TN/BK
6049
Low Reference
32
0.35 L-BU
1162
APP Sensor 2 Signal
33
0.35 GY
2709
5-Volt Reference 1
34
0.35 GY/WH
2700
35
Not Used
36
0.35 TN
1274
5-Volt Reference 1
37
0.5 TN/BK
472
IAT Sensor Signal
38
0.5 TN
2760
Low Reference
39-40
Not Used
41
0.5 YE
492
MAF Sensor Signal
42-46
Not Used
47
0.5 PK/BK
1339
Ignition 1 Voltage
48
Not Used
49
0.5 TN
1671
50
0.35 D-GN/WH
465
51
0.35 TN
1465
52
0.5 YE/BK
625
53-55
Not Used
56
0.35 WH/BK
1164
5-Volt Reference 2
57
0.35 YE/BK
1827
58
0.35 D-GN
335
59
0.35 YE
5991
60
Not Used
61
0.5 WH
1310
62
Not Used
63
0.35 D-GN/WH
459
64
0.5 OG/WH
3223
65
0.5 GY/WH
3122
66-67
Not Used
68
0.35 BN/WH
419
MIL Control
69
0.5 PU
1670
70
0.35 L-BU
1937
71
0.5 PU/WH
821
0.35 OG/BK
6399
72
0.5 L-GN/BK
822
73
3.0 BK/WH
451
Ground
Wire Color
Circuit No.
Function
1
Not Used
2
0.35 PU/WH
6270
5-Volt Reference 2
3
0.35 GY
2701
5-Volt Reference 2
4
Not Used
5
0.5 BN
582
6
0.5 YE
581
7
Not Used
8
0.5 D-GN/WH
428
9
0.5 GY
5493
10
0.5 D-BU
5491
11
0.5 OG
5494
12
0.5 GY/WH
3113
13
0.5 L-GN
3212
14
0.5 L-GN/BK
5492
15
Not Used
16
0.35 PU
5284
17
0.5 D-BU/WH
878
18
0.5 TN/WH
845
19
0.5 YE/BK
846
20
0.5 TN
1744
21
0.5 YE
410
ECT Sensor Signal
22
0.5 TN
2761
Low Reference
23-25
Not Used
26
0.8 D-BU
496
KS 1 Signal
27
0.8 GY
1716
KS 1 Signal
28
Not Used
29
0.8 L-BU
1876
KS 2 Signal
30
0.8 GY
2303
KS 2 Signal
31
Not Used
32
0.5 GY
23
33
0.5 BN
1174
34
0.35 BK
2755
Low Reference
35
0.35 TN
2752
Low Reference
36
Not Used
37
0.5 L-GN/BK
1745
38
0.5 PK/BK
1746
39
0.5 L-BU/BK
844
40
0.5 OG/BK
877
41
0.35 GY
2705
5-Volt Reference 1
42
Not Used
43
0.35 GY
2704
5-Volt Reference 1
44
0.35 D-BU
6259
5-Volt Reference 1
45-49
Not Used
50
0.35 TN/WH
331
51
Not Used
52
0.35 TN
2199
53
0.35 OG/BK
469
Low Reference
54-55
Not Used
56
0.5 TN
1664
57
0.5 PU/WH
1665
58
0.35 L-GN
432
MAP Sensor Signal
59
0.5 PU
1666
60
0.5 TN
1667
61
0.5 BN
25
62
Not Used
63
0.35 PU
486
TP Sensor 2 Signal
64
0.35 D-BU/WH
6265
CMP Sensor Signal
65
0.35 D-GN
485
TP Sensor 1 Signal
66
0.35 BN
6266
Low Reference
67
Not Used
68
0.35 WH/BK
6271
CKP Sensor Signal
69
0.35 GY/BK
6272
Low Reference
70
0.5 PU
2121
IC 1 Control
71
0.5 PU/WH
2128
IC 8 Control
72
0.5 OG
2127
IC 7 Control
73
0.5 OG/WH
2122
IC 2 Control
74
0.5 L-BU/WH
2126
IC 6 Control
75
0.5 D-GN
2125
IC 5 Control
76
0.5 D-GN/WH
2124
IC 4 Control
77
0.5 L-BU
2123
IC 3 Control
78
0.5 BN
2129
Low Reference
79
0.5 BN/WH
2130
Low Reference
80
Not Used
Second for AlldataDIY.com. I used them for both donor and reciever car. Just make sure you download everything you can before your year is up. I didn't, hence my post for a connector diagram for 2005 5.3 Suburban. Good luck.
