Please help identify these connections....
I bought a 6.0 motor from a 2006 GMC truck. I bought a wiring harness for it and have installed that. I do have questions on what a few things are that I'm not sure what should be connected to them.
The first one is on the back of the motor on top, next to the cam sensor.
The second is a hose that attaches to the bottom of the throttle body.
And the third is a fitting on top of the intake that has a tube that leads to the back of the motor, but ends there.
Thanks for the help!
to help further...
1. Don't need to hook this to anything, can remove the sensor and with an adapter use this spot for your oil pressure gauge sensor for your conversion.
2. This would be the spot for the common "throttle body coolant bypass mod" Grab the hose that leads into the other side of the throttle body, from the coolant crossover tube that connects the head and hook it directly to a coolant source for venting the upper cooling system. Maybe your conversion radiator has a spot for a small line into it? Some dump it into the upper radiator hose with an adapter, some drill and tap the water pump area or another coolant source.. many possibilities there.
3. Not doing an emissions compliant swap? forgetaboutit.....
Thanks guys! I bought autometer gauges. The tech from there told me(email) to drill a hole in the plate that's on the block above the oil filter for the oil pressure sending unit and tap it. Mine has an oil cooler, so I'm guessing that's where the plate would have been he'e referring to. I would sure prefer to use the location where the existing oil pressure sending unit is.
to help further...
No emissions. I'll forget about it.
from the factory that line goes through the throttle body and then into the cooling system. This is to keep the throttle body from frosting up in cold weather/ climates. Most of these cars (and swaps) aren't driven in very cold weather so most just skip right past that connection with the hose, bypassing any trip through the throttle body. You can leave the connections on the throttle body open, break them off, weld them shut, paint them blue, hang bananas from them......whatever, they do nothing
For the oil pressure guage, you can get a block off plate for an F-body and drill and tap it for the sender. Or if you're going to use the oil cooler lines, you can take out the original oil sender, break off the plastic part of it, and drill and tap that for the sender. I've done both, they both work well.
Seriously now... Thanks! I may have more questions for you soon.
